BMW E46 330i (M54B30) engine oil leak - causes and solutions
Common leak sources:
  • Valve cover gasket
  • Oil filter housing gasket
  • Oil pan gasket
  • Rear main seal
  • VANOS seals
Diagnostic steps:
  • Clean the engine thoroughly
  • Run the engine and inspect for fresh oil leaks
  • Use UV dye for hard-to-spot leaks
Solutions for common leaks:
  • Valve cover gasket:
    - Remove valve cover
    - Replace gasket (BMW part number: 11127582245)
    - Torque bolts to 10 Nm
  • Oil filter housing gasket:
    - Remove oil filter housing
    - Replace O-rings and gaskets (kit part number: 11421427782)
    - Torque bolts to 22 Nm
  • Oil pan gasket:
    - Support engine
    - Remove front subframe
    - Replace gasket (part number: 11137513050)
    - Torque bolts to 12 Nm
Note: Always replace all accessible gaskets and seals during major repairs to prevent future leaks.
