How to replace BMW E46 318Ci (N42B18) window regulators?
  • Torx T30 driver
  • Flathead and Phillips screwdrivers
  • Plastic trim removal tools
  • 10mm socket and ratchet
Replacement procedure:
  • Remove door panel (be careful of wiring connections)
  • Disconnect window from regulator
  • Remove old regulator (typically 3 or 4 10mm bolts)
  • Install new regulator (OEM part number: 51337020660 for front left)
  • Reconnect window to new regulator
  • Test operation before reinstalling door panel
  • Reinstall door panel
Tips:
  • Apply silicone lubricant to window channels for smoother operation
  • Consider replacing both sides even if only one has failed
  • Check for any signs of water intrusion while door panel is removed
Note: Window regulators are a common failure point on E46 models. Quality replacements can significantly improve long-term reliability.
