BMW E46 M3 (S54B32) differential bushing replacement - DIY approach
Find and decode BMW E46 fault/error codes, access wiring schematics, and follow detailed repair manuals.
  • Hydraulic jack and stands
  • Torque wrench
  • Bushing removal/installation tool
  • Various sockets and wrenches
Replacement procedure:
  • Safely lift and support the rear of the car
  • Remove rear wheels
  • Disconnect driveshaft from differential
  • Support differential and remove mounting bolts
  • Lower differential slightly to access bushings
  • Remove old bushings using appropriate tool
  • Install new bushings (consider polyurethane for improved performance)
  • Reassemble in reverse order
Torque specifications:
  • Differential mount to subframe: 127 Nm
  • Driveshaft to differential flange: 64 Nm
Note: Proper alignment is crucial. Take care not to damage the differential housing during the process.
