How to retrofit cruise control on BMW E46 316i (N45B16)?
Find and decode BMW E46 fault/error codes, access wiring schematics, and follow detailed repair manuals.
Parts needed:
  • Cruise control stalk (part number: 61318363664)
  • Cruise control module (part number: 65718375533)
  • Wiring harness
  • Brake pedal switch (if not already present)
Installation steps:
  • Install brake pedal switch (if necessary)
  • Mount cruise control module behind glove box
  • Run wiring harness from module to steering column
  • Replace steering column switch with cruise control stalk
  • Connect wiring to ECU
  • Code new module using BMW-specific diagnostic tool
Note: Proper coding is essential for the cruise control to function correctly. Consider professional installation if you're not comfortable with automotive electronics.
