Troubleshooting VANOS system issues in BMW E46 330i (M54B30) - symptoms and solutions
Common symptoms:
  • Loss of power, especially at lower RPMs
  • Rough idle
  • Check engine light (codes related to VANOS)
  • Rattling noise from the front of the engine
Diagnostic steps:
  • Perform OBD-II scan for VANOS-related codes
  • Check oil pressure at the VANOS unit
  • Inspect VANOS solenoids and seals
  • Perform VANOS adjustment test using specialized BMW software
Possible solutions:
  • Replace VANOS seals (common and relatively inexpensive fix)
  • Clean or replace VANOS solenoids
  • Rebuild VANOS unit
  • In severe cases, replace entire VANOS system
Note: Regular oil changes with high-quality oil can prevent many VANOS issues.
