How to upgrade BMW E46 323i (M52TUB25) brakes to 330i specs?
Parts needed:
  • 330i front brake calipers (part numbers: 34116750153 and 34116750154)
  • 330i front brake rotors (325mm diameter)
  • 330i brake pads
  • Stainless steel brake lines (optional)
Upgrade procedure:
  • Remove old brake components
  • Install new 330i calipers and carriers
  • Replace rotors with 330i spec (325mm)
  • Install new brake pads
  • Bleed brake system
  • Bed in new brakes properly
Additional considerations:
  • Ensure wheel fitment with larger brakes
  • Consider upgrading brake fluid to high-temperature variant
  • Adjust brake bias if necessary
Note: This upgrade significantly improves braking performance. Ensure all components are properly torqued and the system is bled correctly.
