YouTuber’s Facebook BMW E46 Purchase Takes Unexpected Turn – What Went Wrong?
Posted: Sun Jan 05, 2025 11:25 am
by E46Forum.co.uk
- bmw-3-series-e46.webp (167.57 KiB) Viewed 5579 times
The BMW 3 Series E46, produced between 1997 and 2006, is known for its robust engineering and driving dynamics. However, when purchasing a used E46, particularly one acquired at a low price, it's critical to consider potential issues. Common areas of concern include the M54 inline-6 engine’s oil consumption and leaks, especially around the valve cover gasket and oil filter housing. Additionally, the rear subframe can suffer from rust, which may compromise structural integrity. The cooling system is notorious for failure, where components such as the water pump, thermostat, and expansion tank often require replacement due to age and wear.
Another aspect to keep in mind is the vehicle's electrical systems, including issues with window regulators and ignition coils that can lead to misfires. The E46 can also experience problems with the transmission, notably the ZF 5HP19 automatic transmission, which may exhibit harsh shifting or failure if maintenance records are lacking. Prospective buyers should pay close attention to the vehicle's maintenance history and ensure a thorough inspection before finalizing the purchase, as the low price could be indicative of significant repairs needed.
