a) BMW E46 318i Engine Options: M43 vs N42 Comparison:
- Pre-2001: 1.9L M43 (118 bhp at 5500 rpm, 180 Nm at 3900 rpm)
- Post-2001: 2.0L N42 (143 bhp at 6000 rpm, 200 Nm at 3750 rpm)
- M43: Chain-driven timing, simpler design, more reliable
- N42: Chain-driven, VANOS and Valvetronic systems, more complex
- Oil: 5W-30 or 5W-40 fully synthetic, capacity 4.25L (M43) and 4.5L (N42)
- N42 timing chain replacement costly if neglected (£1000-£1500)
- Inspect plastic expansion tank for cracks; replacement ~£80-£100
- Check water pump and thermostat housing for leaks
- Radiator prone to leaks; replacement cost ~£200-£250
- Coolant flush recommended every 2 years or 30,000 miles
- Check for rust along entire length, especially rear section
- Listen for exhaust leaks, particularly at manifold joints
- Ensure catalytic converter isn't clogged or damaged
- Full exhaust system replacement cost: £450-£600
- Test for play in front control arm bushes; replacement cost £200-£250
- Check rear trailing arm bushes for deterioration
- Ensure power steering is smooth with no whining noises
- Full suspension refresh cost: £800-£1000
- Front: 286mm discs, Rear: 276mm discs
- Check for pad wear and rotor scoring; minimum pad thickness 3mm
- Test ABS function; sensor failures common (£50-£100 per sensor)
- Brake fluid change every 2 years; full brake service cost: £250-£300
- Manual: 5-speed ZF. Check for notchy changes, especially when cold
- Automatic: 5-speed GM 5L40-E. Ensure no slipping or harsh shifts
- Gearbox oil change recommended every 60,000 miles
- Manual gearbox oil change cost: £120-£150
- Automatic transmission fluid and filter change: £200-£250
- Major automatic transmission issues and costs:
- Torque converter failure: £800-£1200
- Complete rebuild: £1800-£2500
- Replacement with reconditioned unit: £2200-£3000 - Signs of automatic transmission problems:
- Delayed engagement or slipping between gears
- Unusual noises when in gear or shifting
- Transmission fluid leaks or burning smell
- Test all powered accessories (windows, mirrors, sunroof)
- Check for dim pixels in instrument cluster; repair cost £100-£150
- Ensure all warning lights function correctly
- Window regulator failures common; replacement cost £130-£160 per window
- Inspect sills and rear wheel arches for rust
- Check panel gaps for accident damage signs
- Look for stone chips on bonnet and front bumper
- Sunroof drains can block, causing water ingress; cleaning cost £50-£80
- Check seat bolsters and steering wheel for wear
- Test all climate control functions
- Ensure no warning lights stay on after startup
- Verify operation of all interior lights and switches
- Verify service stamps match mileage progression
- Look for timing chain replacement on high-mileage N42 engines
- Check for regular oil changes (10,000 miles or annually)
- Major service interval: every 36,000 miles or 2 years
- LCI models have updated headlights and taillights (clear indicators)
- Interior received minor updates, including new door panels and steering wheel
- N42 engine introduced more power and improved efficiency in LCI models
- LCI models have slightly updated suspension for improved handling
- M43: Oil leaks from rocker cover common; replacement gasket cost £50-£80
- N42: VANOS issues can cause rough running; repair cost £400-£600
- Both: Window regulators prone to failure; replacement cost £130-£160 per window
- Coolant expansion tank cracks; replacement cost £80-£100
- ABS sensor failures; replacement cost £60-£80 per sensor
- Check for smooth cold start and idle
- Test acceleration through all gears, noting any hesitation or misfires
- Listen for suspension noises over rough roads
- Check brake performance, including handbrake efficiency
- Verify all electrical systems work correctly during the drive
- Verify VIN matches all documentation
- Check for any outstanding recalls using the DVSA website
- Ensure all keys and master key are present
- Verify MOT history online for consistency and past issues
- Check for non-standard ECU tunes; may affect reliability if not done properly
- Beware of lowered suspensions affecting ride quality; check for proper installation
- Ensure any performance upgrades are properly documented for insurance
- Popular upgrades include cold air intakes and exhaust systems; verify quality of parts used
- More premium feel than mainstream rivals like Ford Focus or Vauxhall Astra
- Better handling but potentially higher running costs than Japanese alternatives
- Strong residual values compared to non-premium brands
- Higher servicing costs, typically 20-30% more than mainstream brands
- Minor service: £150-£200, Major service: £300-£400
- Timing chain replacement on N42: £1000-£1500
- Budget for potential cooling system overhaul: £500-£700
- Annual maintenance budget for a well-used example: £600-£800
- Factor in potential for larger one-off repairs (e.g., transmission) when budgeting
- Excellent availability of both OEM and aftermarket parts
- Example prices:
- Oil filter: £10-£15 (Mann or Bosch), £20-£25 (OEM BMW)
- Air filter: £20-£25 (Mann or Bosch), £30-£35 (OEM BMW)
- Brake pads (front): £40-£50 (Pagid or Brembo), £70-£80 (OEM BMW)
- Shock absorbers (pair, front): £120-£150 (Bilstein), £200-£240 (OEM BMW)
- Consider used parts from breakers for cost savings on larger components
- As of 2023, average asking prices:
- Under 80,000 miles, excellent condition: £2,500-£4,000
- 80,000-120,000 miles, good condition: £1,800-£3,000
- Over 120,000 miles, fair condition: £1,200-£2,200
- Well-maintained, low mileage examples (under 60,000 miles) can fetch up to £4,500-£5,500
- Annual depreciation now typically 5-7% for well-maintained examples
- N42 engine models (post-2001) generally command a 10-15% premium over M43 models
- Convertible and Touring models typically fetch 10-20% more than equivalent saloons
