BMW E46 320i Pre-Facelift: A Comprehensive Buyer's Guide
Get model guides, tips on inspections, common issues and what to look for when hunting for your perfect BMW E46.
BMW E46 320i Pre-Facelift: The Full Buying Guide
a) BMW E46 320i Pre-Facelift Engine Specifications and Maintenance:
  • 2.0L M52TU engine, producing 150 bhp at 5900 rpm and 190 Nm of torque at 3500 rpm
  • Double VANOS system: Listen for rattling noise at idle, indicating worn seals
  • Timing chain should last 150,000+ miles; listen for rattling noise at startup indicating stretch
  • Use only 5W-30 or 0W-40 fully synthetic oil; capacity is 6.5 liters including filter
  • Oil change interval: every 10,000 miles or annually, whichever comes first
  • Check for oil leaks: valve cover gasket, oil filter housing gasket, and VANOS solenoid seals
b) BMW E46 320i Pre-Facelift Cooling System: Common Failures and Prevention:
  • Inspect radiator for leaks, especially lower corners; replacement cost £250-£300
  • Check plastic coolant expansion tank for cracks; replace if older than 7 years, cost £50-£70
  • Water pump failure common after 60,000 miles; listen for rumbling noise from front of engine
  • Thermostat typically fails around 80,000 miles; check for consistent temperature gauge reading
  • Full cooling system overhaul recommended every 60,000-80,000 miles, costing £500-£700
c) BMW E46 320i Pre-Facelift Exhaust System: Inspection Points and Replacement Costs:
  • Examine entire exhaust for rust, focusing on middle section and back box
  • Listen for exhaust leaks, particularly at manifold joints and flex pipe
  • Catalytic converter failure common after 100,000 miles; check for rattling noise and loss of power
  • Full exhaust system replacement (excluding manifold) costs £600-£800 at an independent garage
d) BMW E46 320i Pre-Facelift Suspension and Steering: Wear Indicators and Repair Costs:
  • Check front control arm bushes for play: grasp wheel at 9 and 3 o'clock positions and rock
  • Inspect rear trailing arm bushes for cracks or deterioration
  • Test power steering: should be smooth with no whining; whining indicates low fluid or pump failure
  • Front shock absorbers typically last 60,000-80,000 miles; test by bouncing each corner of the car
  • Full suspension refresh (bushes, shocks, springs) costs £1000-£1200 at a specialist
e) BMW E46 320i Pre-Facelift Braking System: Maintenance Schedule and Inspection Guide:
  • Front: 300mm discs, Rear: 294mm discs
  • Check disc thickness: minimum 28mm front, 20mm rear
  • Inspect for even pad wear; minimum pad thickness is 3mm
  • Ensure brake fluid has been changed every 2 years; dark color indicates overdue change
  • ABS sensor failures common; each sensor costs £80-£100 to replace
  • Full brake service (discs and pads all round) costs £400-£500 at an independent garage
f) BMW E46 320i Pre-Facelift Transmission Options: Manual and Automatic Gearbox Care:
  • Manual: 5-speed ZF. Check for smooth shifts, no crunching especially in 2nd gear
  • Automatic: 5-speed GM 5L40-E. Ensure no slipping or harsh shifts, particularly from 2nd to 3rd
  • Transmission fluid change recommended every 60,000 miles, costs £150-£200
  • Listen for whining noise in manual gearbox, indicating bearing wear
  • Check for leaks at bell housing and differential seals
  • Major automatic transmission repairs can be costly:
    - Valve body replacement: £900-£1300
    - Full rebuild: £1800-£2800
    - Replacement with reconditioned unit: £2200-£3200
  • Signs of automatic transmission issues:
    - Delayed engagement when shifting from Park to Drive
    - Slipping gears or sudden jerks during acceleration
    - Unusual noises (whining, humming) when in gear
    - Transmission fluid leaks or burning smell
g) BMW E46 320i Pre-Facelift Electrical System: Common Faults and Diagnostic Procedures:
  • Test all electrical components: windows, mirrors, sunroof, wipers, lights
  • Check for airbag warning lights; faulty seat occupancy sensor common, costs £200-£300 to fix
  • Ensure DSC (Dynamic Stability Control) light goes off after startup
  • Test cooling fan operation: should activate when engine is warm and A/C is on
  • Dim pixels in instrument cluster common; repair costs £100-£150
  • Check for battery drain issues; faulty boot wiring loom can cause this
h) BMW E46 320i Pre-Facelift Body and Corrosion: Rust-Prone Areas and Inspection Tips:
  • Inspect rear wheel arches and sills for rust, particularly behind plastic trim
  • Check for even panel gaps: should be 4-5mm consistently
  • Look for stone chips on bonnet and front bumper; signs of rust indicate poor previous repairs
  • Check sunroof drains for blockages; water in footwells indicates blocked drains
  • Inspect windscreen for chips or cracks; replacement costs £200-£300
  • Check door bottoms and boot seal area for early signs of corrosion
i) BMW E46 320i Pre-Facelift Interior: Quality Assessment and Common Wear Points:
  • Check driver's seat bolster for wear; leather re-coloring costs around £150
  • Ensure all dashboard lights illuminate on startup and then go off
  • Test climate control in all settings; weak airflow indicates blocked pollen filter
  • Verify electric seat adjustments work smoothly if fitted
  • Inspect headlining for sagging, particularly around sunroof
  • Check for wear on steering wheel, gear knob, and handbrake lever
j) BMW E46 320i Pre-Facelift Service History and Mileage Verification:
  • Look for stamps from BMW dealers or recognized specialists
  • Verify mileage against MOT history (check online) and service records
  • Timing chain tensioner should have been updated on early models (pre-2001)
  • Major service should occur every 30,000 miles, including spark plug replacement
  • Inspect brake fluid for regular changes (every 2 years)
  • Check for documented cooling system overhaul around 60,000-80,000 miles
k) BMW E46 320i Pre-Facelift Specific Features and Identification:
  • Pre-Facelift models have amber indicator lenses front and rear
  • Headlights have separate high beam reflector
  • Earlier style interior trim uses more plastic compared to LCI models
  • Pre-Facelift models have a different front bumper design with round fog lights
  • Check production date on VIN plate to confirm Pre-Facelift status (before September 2001)
l) Common Mechanical and Electronic Issues in BMW E46 320i Pre-Facelift:
  • VANOS seals fail causing rough idle and poor performance; repair costs £500-£700
  • Crankcase ventilation valve failure leads to oil leaks and rough running; replacement costs £100-£150
  • Window regulators prone to failure, especially front doors; each regulator costs £150-£200 to replace
  • Radiator plastic end tanks crack; full replacement needed, costs £250-£300
  • ABS module failure can occur; repair or replacement costs £500-£800
m) BMW E46 320i Pre-Facelift Test Drive Checklist:
  • Cold start: Listen for timing chain rattle, should subside within 5 seconds
  • Check for smooth acceleration through all gears, no hesitation or misfires
  • Test brakes for even stopping power and no pulling to one side
  • Drive over rough roads to check for suspension knocks or rattles
  • Ensure temperature gauge stays steady at 12 o'clock position during drive
  • Verify smooth operation of VANOS system across entire rev range
  • Check for any unusual vibrations, especially at higher speeds
n) BMW E46 320i Pre-Facelift Documentation and Legal Aspects:
  • Verify full V5C document is present and matches car details
  • Check for outstanding finance using online HPI check (costs about £20)
  • Ensure all previous MOT certificates are available; check for advisories
  • Verify service book entries match mileage progression
  • Check for any outstanding recalls, particularly for airbag systems
  • Confirm insurance group (32) for accurate insurance quotes
o) BMW E46 320i Pre-Facelift Modifications and Tuning: Performance Upgrades and Considerations:
  • Popular upgrades include ECU remap (adds 15-20 bhp), costing £300-£400
  • Aftermarket exhausts common; ensure cat-back systems to maintain emissions compliance
  • Check for non-standard suspension; lowering springs can affect ride quality
  • Verify any engine modifications are properly documented for insurance purposes
  • Be cautious of cars with extensive modifications; they may indicate hard use
p) BMW E46 320i Pre-Facelift vs Competitors: Performance and Ownership Cost Comparison:
  • More refined than contemporary Audi A4 1.8T or Mercedes C200K
  • Better handling but 10-15% higher maintenance costs compared to Ford Mondeo ST220
  • Fuel economy: expect 28-32 mpg combined, compared to 26-30 mpg for Mercedes C200K
  • Higher prestige factor but potentially costlier to maintain than mainstream brands
  • Stronger residual values compared to non-premium competitors of the same era
q) BMW E46 320i Pre-Facelift Maintenance Costs: Annual and Long-term Expectations:
  • Annual service: £200-£300 at independent specialists, £350-£450 at BMW dealers
  • Major service (every 30,000 miles): £400-£500 at independent, £600-£700 at dealers
  • Timing chain replacement (if needed): £800-£1000 at independent specialist
  • Budget £500-£700 annually for maintenance and repairs on a well-used example
  • Cooling system overhaul (recommended every 60,000-80,000 miles): £500-£700
  • Brake fluid change (every 2 years): £60-£80
  • Automatic transmission fluid change (every 60,000 miles): £150-£200
  • Suspension refresh (around 100,000 miles): £800-£1000
  • Unexpected repairs: Budget an additional £500-£1000 per year for older vehicles
  • Potential major expenses:
    - VANOS repair: £500-£700
    - Automatic transmission rebuild: £1500-£2500
    - Engine rebuild (rare but possible): £3000-£5000
  • Consider setting aside 10-15% of the car's value annually for maintenance and repairs
r) BMW E46 320i Pre-Facelift Parts Availability and Cost Comparison:
  • Good availability of both OEM and aftermarket parts
  • Example prices:
    - Oil filter: £8-£12 (Mann or Bosch), £15-£20 (OEM BMW)
    - Air filter: £15-£20 (Mann or Bosch), £25-£30 (OEM BMW)
    - Brake pads (front): £30-£40 (Pagid or Brembo), £60-£70 (OEM BMW)
    - Shock absorbers (pair, front): £100-£120 (Bilstein), £180-£200 (OEM BMW)
    - Alternator: £150-£200 (Bosch), £300-£350 (OEM BMW)
    - Water pump: £50-£70 (FEBI), £100-£120 (OEM BMW)
  • Consider joining owners' clubs for access to group buys and specialist suppliers
  • Some electronic components (e.g., ECU) only available from BMW, costing £800-£1000
  • Aftermarket performance parts widely available but may affect warranty and insurance
s) BMW E46 320i Pre-Facelift Market Value and Depreciation Trends:
  • As of 2023, average asking prices:
    - Under 80,000 miles, excellent condition: £3,000-£5,000
    - 80,000-120,000 miles, good condition: £2,000-£3,500
    - Over 120,000 miles, fair condition: £1,500-£2,500
  • Exceptional low-mileage examples (under 50,000 miles) can fetch £6,000-£7,000
  • Expect 5-10% annual depreciation, less for well-maintained, low-mileage examples
  • Cars in the South East and London typically command 10-15% higher prices
  • Coupe and Convertible models generally fetch 15-20% more than equivalent Saloons
  • Sport models with M-Sport packages can command a 10-15% premium
  • Factors affecting value: full service history, recent major repairs completed, original paint, no accident history
  • Future classic potential may stabilize values for well-kept examples
