BMW E46 328i: In-Depth Inspection Guide for Savvy Buyers
Get model guides, tips on inspections, common issues and what to look for when hunting for your perfect BMW E46.
a) BMW E46 328i Engine Characteristics and Potential Issues:
  • 2.8L M52TU engine (193 bhp at 5500 rpm, 280 Nm at 3500 rpm)
  • Double VANOS system: Listen for rattling noise at idle, indicating worn seals
  • Timing chain designed for engine's lifetime but can stretch at high mileage
  • Timing chain replacement typically needed around 150,000-180,000 miles
  • Timing chain replacement cost: £1000-£1500 at independent specialist
  • Failure to replace stretched timing chain can lead to catastrophic engine failure, potentially costing £4000-£6000 for a replacement engine
  • Oil capacity: 6.5 liters; use only 5W-30 or 0W-40 fully synthetic oil
  • Oil change interval: 15,000 miles or annually, whichever comes first
  • Check for oil leaks around valve cover gasket and oil filter housing
  • Listen for ticking noise indicating lifter or valvetrain issues
b) BMW E46 328i Cooling System: Common Failures and Preventive Measures:
  • Plastic expansion tank prone to cracking; replacement cost £80-£100
  • Water pump typically fails around 60,000-80,000 miles; replacement cost £200-£250
  • Thermostat and housing can leak; check for coolant residue
  • Radiator can develop leaks, especially in lower corners; replacement cost £250-£300
  • Electric fan failure can cause overheating; replacement cost £150-£200
  • Full cooling system overhaul recommended every 60,000 miles, total cost £700-£900
c) BMW E46 328i Transmission Options: Manual and Automatic Gearbox Care:
  • Manual: ZF 5-speed, generally reliable but check for smooth operation
  • Manual transmission issues:
    - Clutch typically lasts 80,000-100,000 miles; replacement cost £600-£800
    - Listen for grinding noises, especially in 2nd gear, indicating synchro wear
    - Clutch hydraulics can fail; slave cylinder replacement costs £180-£220
    - Gearbox oil should be changed every 60,000 miles; neglect can lead to premature wear
  • Automatic: ZF 5-speed, ensure smooth shifts and no slipping
  • Automatic transmission issues:
    - Fluid and filter change recommended every 50,000 miles; cost £250-£300
    - Neglecting fluid changes can lead to premature failure
    - Valve body issues common; replacement costs £900-£1300
    - Torque converter failure possible; replacement with rebuild costs £2000-£2800
    - Complete transmission failure if maintenance neglected; rebuild or replacement costs £2800-£3800
  • Check for leaks at transmission seals and gaskets
  • Ensure smooth gear changes in both manual and automatic
  • Verify no slipping or harsh engagement in automatic, especially when cold
d) BMW E46 328i Suspension and Steering: Wear Indicators and Replacement Costs:
  • Front control arm bushings prone to wear; replacement cost £250-£300
  • Rear trailing arm bushings can deteriorate; affects handling
  • Check for even tire wear; uneven wear indicates alignment issues
  • Power steering pump can fail; listen for whining noise
  • Shock absorbers typically last 60,000-80,000 miles; replacement cost £400-£500 for all four
  • Full suspension refresh cost: £1000-£1300 at specialist
e) BMW E46 328i Electrical System: Common Faults and Diagnostic Tips:
  • Check all electrical components: windows, mirrors, lights, wipers
  • Ensure ABS and traction control lights go out after startup
  • Dim pixels in instrument cluster common; repair cost £120-£180
  • Battery drain issues can occur; check for parasitic draw
  • Alternator failure possible at high mileage; replacement cost £280-£350
  • Verify all warning lights illuminate briefly on startup
f) BMW E46 328i Body and Corrosion: Rust-Prone Areas and Inspection Guide:
  • Inspect rear wheel arches and sills for rust, especially behind plastic trims
  • Check front fenders near headlights for corrosion
  • Sunroof drains can block, causing water ingress; check footwells for dampness
  • Door bottoms can rust; look under rubber seals
  • Boot lid can corrode around number plate lights
  • Check for even panel gaps, indicating possible previous accident repairs
g) BMW E46 328i Braking System: Maintenance Schedule and Common Issues:
  • Front: 325mm discs, Rear: 320mm discs
  • Check for pad wear and rotor scoring; minimum pad thickness 3mm
  • Test ABS function; sensor failures common (£60-£80 per sensor)
  • Brake fluid change every 2 years; full brake service cost: £300-£400
  • Listen for squealing or grinding noises during braking
h) BMW E46 328i Service History and Mileage Verification:
  • Verify service stamps match mileage progression
  • Look for timing chain replacement on high-mileage engines
  • Check for regular oil changes (15,000 miles or annually)
  • Major service interval: every 30,000 miles or 2 years
  • Verify coolant system overhaul around 60,000-80,000 miles
i) BMW E46 328i Pre-Facelift vs Facelift Models: Key Differences:
  • Facelift introduced in late 2001
  • Updated headlights and taillights on facelift models
  • Interior received minor updates, including new door panels
  • Engine remained largely unchanged between versions
  • Facelift models have slightly updated suspension for improved handling
j) BMW E46 328i Test Drive Checklist: Key Points to Assess:
  • Check for smooth cold start and idle
  • Test acceleration through all gears, noting any hesitation or misfires
  • Listen for suspension noises over rough roads
  • Check brake performance, including handbrake efficiency
  • Verify all electrical systems work correctly during the drive
  • Monitor temperature gauge for consistent reading
k) BMW E46 328i Maintenance Costs: Annual Budget and Major Expense Planning:
  • Annual service: £200-£300 at independent specialists, £350-£450 at BMW dealers
  • Major service (every 30,000 miles): £400-£500 at independent, £600-£700 at dealers
  • Timing chain replacement (if needed): £1000-£1500
  • Budget £700-£900 annually for maintenance on a well-used example
  • Factor in potential for larger one-off repairs (e.g., transmission) when budgeting
l) BMW E46 328i Common Mechanical and Electronic Issues:
  • VANOS seals failure causing rough idle and poor performance
  • Crankcase ventilation valve failure leading to oil leaks and rough running
  • Window regulators prone to failure, especially front doors
  • ABS module failures can occur; check for ABS warning lights
  • Oxygen sensor failures can cause poor fuel economy and engine performance
m) BMW E46 328i Interior Quality and Common Wear Points:
  • Check driver's seat bolster for wear; leather re-coloring costs around £150
  • Ensure all dashboard lights and displays function correctly
  • Verify smooth operation of climate control system
  • Inspect headliner for sagging, especially around sunroof
  • Test all audio system components, including CD changer if present
n) BMW E46 328i Documentation and Legal Aspects:
  • Verify full V5C document is present and matches car details
  • Check for outstanding finance using online HPI check (costs about £20)
  • Ensure all previous MOT certificates are available; check for advisories
  • Verify service book entries match mileage progression
  • Check for any outstanding recalls, particularly for airbag systems
o) BMW E46 328i Modifications and Tuning: Performance Upgrades and Considerations:
  • Popular upgrades include ECU remap (adds 15-20 bhp), costing £300-£400
  • Aftermarket exhausts common; ensure cat-back systems to maintain emissions compliance
  • Check for non-standard suspension; lowering springs can affect ride quality
  • Verify any engine modifications are properly documented for insurance purposes
  • Be cautious of cars with extensive modifications; they may indicate hard use
p) BMW E46 328i vs Competitors: Performance and Ownership Cost Comparison:
  • More refined than contemporary Audi A4 2.8 or Mercedes C280
  • Better handling but potentially higher maintenance costs compared to Japanese rivals
  • Fuel economy: expect 25-30 mpg combined, compared to 23-28 mpg for Mercedes C280
  • Higher prestige factor but potentially costlier to maintain than mainstream brands
  • Stronger residual values compared to non-premium competitors of the same era
q) BMW E46 328i Long-Term Ownership Considerations:
  • Parts availability generally good, but some electronic components may become scarce
  • Consider joining owners' clubs for advice and potential group buys on parts
  • Insurance costs can be higher than average due to performance and repair costs
  • Potential for future classic status, especially for well-maintained examples
  • Consider specialized storage solutions if keeping the car long-term
r) BMW E46 328i Parts Availability and Cost Comparison:
  • Good availability of both OEM and aftermarket parts
  • Example prices:
    - Oil filter: £10-£15 (Mann or Bosch), £20-£25 (OEM BMW)
    - Air filter: £20-£25 (Mann or Bosch), £35-£40 (OEM BMW)
    - Brake pads (front): £40-£60 (Pagid or Brembo), £80-£100 (OEM BMW)
    - Shock absorbers (pair, front): £120-£150 (Bilstein), £220-£260 (OEM BMW)
    - Alternator: £180-£220 (Bosch), £350-£400 (OEM BMW)
  • Consider joining owners' clubs for access to group buys and specialist advice
s) BMW E46 328i Market Value and Depreciation Trends:
  • As of 2023, average asking prices:
    - Under 80,000 miles, excellent condition: £4,000-£6,000
    - 80,000-120,000 miles, good condition: £2,500-£4,000
    - Over 120,000 miles, fair condition: £1,500-£2,500
  • Well-maintained, low mileage examples can fetch up to £7,000-£8,500
  • Expect 5-8% annual depreciation for average examples
  • Coupe and Convertible models typically command 15-20% premium over Saloons
  • M-Sport models can fetch 10-15% more than standard versions
  • Factors boosting value: full service history, recent major work completed, original paint, no accident history
