Upgrading BMW E46 325i (M54B25) suspension to M3 specifications
Components to upgrade:
  • Shocks and springs
  • Control arms
  • Sway bars
  • Bushings
  • Subframe reinforcement
Upgrade process:
  • Install M3 spec coilovers or shocks/springs
  • Replace control arms with M3 parts
  • Upgrade to M3 spec sway bars
  • Replace all bushings with polyurethane or M3 rubber
  • Reinforce subframe mounting points
  • Perform four-wheel alignment
Performance improvements:
  • Enhanced handling and cornering ability
  • Improved steering response
  • Reduced body roll
  • Better overall driving dynamics
Note: This comprehensive upgrade significantly changes the car's handling characteristics. Ensure all components are properly installed and aligned for best results and safety.
