The BMW M54 engine (found in E46 models like the 325i and 330i) is a smooth straight-six, but it's known for a few common issues, particularly oil consumption and problems with the Crankcase Centilation (CCV) system and DISA valve.
This thread is for UK owners to discuss:
- Oil Consumption: How much oil does your M54 use? What do you consider "normal" vs. excessive? Have you found any effective ways to reduce it (e.g., different oil grades - 5W-30, 5W-40, piston soak, etc.)?
- CCV System (Oil Separator): Symptoms of a failing CCV (e.g., blue smoke, high oil consumption, whistling noises, vacuum issues)? Best replacement kits available in the UK? Is the cold-climate version essential for the UK? DIY difficulty and tips?
- DISA Valve: Telltale signs of a failing DISA valve (rattling, loss of low-end torque, fault codes)? Repair kits vs. new unit? Recommended UK suppliers for parts? DIY guides and experiences.
- VANOS Seals: While we're at it, many M54s suffer from tired VANOS seals. Symptoms and recommended UK kits (e.g., Beisan Systems)?
- Other M54 Specifics: Any other common oil leaks (OFHG, sump gasket) or maintenance tips specific to the M54 in the E46?
Please state your E46 model (325i/330i), year, and mileage when sharing your experiences.
Looking forward to your input!
