- Cooling system failure:
- Replace expansion tank, radiator, and water pump preventively
- Use quality parts and proper coolant - Window regulator issues:
- Replace with updated parts
- Lubricate tracks regularly - Oil leaks:
- Check and replace valve cover gasket, oil filter housing gasket, and oil pan gasket
- Use high-quality gaskets and proper torque specs - VANOS system problems:
- Replace VANOS seals
- Consider rebuilding or replacing the VANOS unit if issues persist - Suspension wear:
- Replace control arm bushings, ball joints, and shock absorbers
- Upgrade to polyurethane bushings for longevity - Alternator failure:
- Replace with a high-quality alternator
- Check and replace serpentine belt if necessary
Common BMW E46 325i (M54B25) problems and how to fix them
- Similar Topics
- Replies
- Views
- Last post
- 0 Replies
- 5268 Views
Last post by E46Forum.co.uk
- 0 Replies
- 5766 Views
Last post by spinecki
- 0 Replies
- 7536 Views
- 0 Replies
- 4037 Views
- 0 Replies
- 4594 Views
- 0 Replies
- 8849 Views
- 0 Replies
- 4960 Views
- 0 Replies
- 6583 Views
- 0 Replies
- 9974 Views
- 0 Replies
- 7000 Views
