Common BMW E46 325i (M54B25) problems and how to fix them
- Cooling system failure:
- Replace expansion tank, radiator, and water pump preventively
- Use quality parts and proper coolant - Window regulator issues:
- Replace with updated parts
- Lubricate tracks regularly - Oil leaks:
- Check and replace valve cover gasket, oil filter housing gasket, and oil pan gasket
- Use high-quality gaskets and proper torque specs - VANOS system problems:
- Replace VANOS seals
- Consider rebuilding or replacing the VANOS unit if issues persist - Suspension wear:
- Replace control arm bushings, ball joints, and shock absorbers
- Upgrade to polyurethane bushings for longevity - Alternator failure:
- Replace with a high-quality alternator
- Check and replace serpentine belt if necessary
