Replacing BMW E46 320d (M47D20) expansion tank and thermostat - preventive maintenance
Parts needed:
  • Expansion tank (part number: 17117573781)
  • Thermostat (part number: 11517787113)
  • Coolant (BMW-approved)
  • Various hose clamps
Replacement procedure:
  • Drain cooling system
  • Remove old expansion tank and thermostat
  • Install new thermostat with fresh O-ring
  • Install new expansion tank
  • Refill cooling system with proper coolant mix
  • Bleed cooling system thoroughly
  • Check for leaks and proper operation
Preventive tips:
  • Replace these components every 60,000-80,000 miles
  • Inspect cooling system regularly for signs of wear or leaks
  • Use only BMW-approved coolant
Note: Proper bleeding of the cooling system is crucial to prevent overheating issues.
