Tools needed:
- Torx T30 driver
- Flathead and Phillips screwdrivers
- Plastic trim removal tools
- 10mm socket and ratchet
- Remove door panel (be careful of wiring connections)
- Disconnect window from regulator
- Remove old regulator (typically 3 or 4 10mm bolts)
- Install new regulator (OEM part number: 51337020660 for front left)
- Reconnect window to new regulator
- Test operation before reinstalling door panel
- Reinstall door panel
- Apply silicone lubricant to window channels for smoother operation
- Consider replacing both sides even if only one has failed
- Check for any signs of water intrusion while door panel is removed
