BMW E46 330xi (M54B30) steering rack replacement - symptoms and procedure
Find and decode BMW E46 fault/error codes, access wiring schematics, and follow detailed repair manuals.
Symptoms of failing steering rack:
  • Fluid leaks
  • Stiff or inconsistent steering
  • Clicking or clunking noises when turning
  • Excessive play in steering wheel
Replacement procedure overview:
  • Raise and safely support the front of the car
  • Remove front wheels and undertray
  • Disconnect tie rods and steering column
  • Remove power steering lines from rack
  • Unbolt and remove old steering rack
  • Install new rack (part number: 32136751745)
  • Reconnect all components
  • Refill and bleed power steering system
  • Perform wheel alignment
Important notes:
  • Consider replacing tie rods and bellows during rack replacement
  • Use only specified power steering fluid
  • Torque all fasteners to factory specifications
Note: This is a complex job that significantly affects steering and safety. Professional installation is recommended if you're not confident in your abilities.
