Symptoms of failing steering rack:
- Fluid leaks
- Stiff or inconsistent steering
- Clicking or clunking noises when turning
- Excessive play in steering wheel
- Raise and safely support the front of the car
- Remove front wheels and undertray
- Disconnect tie rods and steering column
- Remove power steering lines from rack
- Unbolt and remove old steering rack
- Install new rack (part number: 32136751745)
- Reconnect all components
- Refill and bleed power steering system
- Perform wheel alignment
- Consider replacing tie rods and bellows during rack replacement
- Use only specified power steering fluid
- Torque all fasteners to factory specifications
