Common symptoms:
- Water dripping from headliner
- Wet carpets or footwells
- Musty smell in the car
- Remove A-pillar trim and sunroof trim
- Locate sunroof drain tubes (front and rear)
- Use compressed air or a flexible wire to clear blockages
- If tubes are damaged, replace them
- Clean sunroof tray and check for proper drainage
- Apply silicone lubricant to sunroof seals
- Regularly clean sunroof drains (every 1-2 years)
- Keep sunroof closed during car washes
- Address any leaks promptly to prevent water damage
